- Jun 5, 2013
- 144
I've kept the FC over 10 for more than a week now, and checked last night at sunset and had 19 FC. This morning I tested again and have 19 FC. CC test gives the water sample a hint of red, which goes away with a single drop of the FC test. This suggests to me that all life in the pool is dead, it is simply a mater of filtering the water until clear. Clarity is still frustratingly slow at improving. That has been my experience with previous SLAMs. Not sure if my sand filter could be a bit low on sand, reducing filtering speed. I did refill it several years back with the recommended lbs of sand, but it seemed to only leave the filter roughly 1/2 full. (Added note for clarity: I refilled the filter because I replaced the lateral assembly after I opened the filter and it the downpipe to the lateralls broke. So I had a completely empty filter and added the recommended weight in sand) Seemed odd to make such a big filter housing and only call for a 1/2 fill.
I've considered adding DE in years past, to help speed things along, but I've never picked any up, and over time the water does get perfectly clear. (Can clearly see my son's fingers across a 32' pool underwater with goggles.)
I know the official advise is to keep SLAMing until water is clear, color is gone, and overnight test passes. I passed the overnight test (SWG was off last night) and I did dose roughly 2.5 lbs of CYA the other day to slow the sunlight's appetite.
TF-100 refill kit due to come in the mail tomorrow. I'm of the opinion to fill the water to the skimmer level, relax on FC, get test numbers tomorrow, and work toward getting salt and CYA levels up if everything continues to improve.
