- May 26, 2010
- 305
- Vinyl
- CircuPool RJ-45
Hi. I have a meter located about 4ft from the filter and just before the heater. All my lines above and under ground are 1 1/2" pvc. I have 1 suction line. It's the line from the skimmer to the pump. About 15ft. The line comes out of the ground by about a foot and then is connected to the pump with a horizontal connection distance of maybe 7". Doesn't seem like much opportunity to increase my flow rate. Is it mostly effected by the suction side only? On the pressure side, it comes out of the heater and then into the salt gen and then to the return valves. I'm looking to install a variable speed pump this spring. Was just looking to maximize my starting point.
Looking for any ideas on increasing flow rate if possible. Obviously, replacing the underground lines with 2" is not possible at this point.
Thanks
Rich
Thanks
Rich
