I am installing a Raypak Propane heater 15' away from the pool (15' x 48" steel sided pool). Figured be better than having pump and heater right next to pool for various reasons.
I am using Flexible PVC pipe. In Iowa. No termites in area. Yes I am going to bury it. I would need to go down over 6' to get below frost line. Ground can heave. You would have to be very careful to properly fill in with pvc or it would crack.
I thought what if I used drainage tile that is slit to allow water to also drain out. This would protect it from rodents like moles and rocks. This seems for the home owner special best of both worlds. I was going to rent a ditch witch trencher and go 3' deep. Not sure if two 1.5" pipes would fit in a drainage tile 3" in size. Maybe do two runs?
Just a idea. Thoughts beyond don't do and use PVC instead. I am not going to go down deep enough.
