RDspaguy
In The Industry
James is right, it has to be a pressure fitting.
An inside fitting can work, but surface prep is crucial. If the pipe is bubbly on the inside it will fail.
You can see for yourself if the joint is good when you pull that drain fitting off.
@JamesW , you seem determined that this method that I have used countless times over the last 25 years will not work. Do you have a better solution? Can you recommend anything to help, or just try to discredit my suggestion? Replumbing is not an option, that has already been determined. You are clearly a spa expert so must have dealt with this many times. What do you suggest?
Don't do the glue buildup thing. If you need to do that, the coupling is too loose.
