- Jun 8, 2019
- 4,581
- Vinyl
- Pentair Intellichlor IC-60
I don’t believe there’s any steel behind the liner. It was all concrete and some padding. See below photo from 2019 when liner was replaced the year we moved in. The light is immediately below the diving board (covered by padding from before we taped it back into place).I think it is your steel wall behind the fixture that is rusting and the rust is coming through the penetrations and showing on the fixture.
It is not the fixtures you need to fix but the wall behind it. That fix is likely when you replace the liner and see how bad your rust cancer is.
There’s a few spots the liner is out of place, but it hasn’t been enough that I’ve been concerned about it yet, from what I’ve seen.It looks as if your liner is pulling out near the skimmer which could be allowing water to get where it shouldn’t contributing to the rust there.
If you can’t get it fully back in you may need to try some liner lock. Hopefully others will chime in soon with more pointers.
Try a magnet.I don’t believe there’s any steel behind the liner.
Try a magnet.
Sure.Do you have more pics ? The walls sure look like inidivual pieces in the pic you posted. Concrete would be a solid pour.
….how are you guys right so often, I just don’t understandTry a magnet.
Yes, magnet stuck. So I have rusting in the steel walls that’s leeching out around my light, skimmer plate, etc.? I guess I live with it?You can't really replace the walls without a major construction project.
You can maybe paint them when you replace the liner.
Not much that you can do until you replace the liner.
Walls are either polymer or galvanized steel.
A magnet will not stick to polymer, so if a magnet sticks to the walls, the walls are galvanized steel.
It doesn't scrub off with a soft-bristle pool brush. Not sure what else to try with it right next to the liner.Are you able to scrub it off the niche?
I'll give it a go.Vitamin C on a rag might work.
Or just sprinkle the vitamin C on the spot and let it sit there.
