I'm going to use what use to be the PVC line for a pool cleaner and wondering what is the best way to fish a new line down it seeing as there are probably going to some 90 deg bends in the PVC ?
Going to repurpose a vacuum line for a screw in pool light. Need to fish a new line down it but there are a couple tight bends a normal wire fish won't go past.Help us to visualize what you are doing. You have an old PVC cleaning/vacuum line you want to repurpose correct? If so, what are you going to use it for? Another return jet? Something else? Or did I completely misunderstand the question.Pics may help.
Nice. I guess you could make an "elbow" that screws into the pool-side outlet and brings the pipe above the water line?Typically I get a small plastic grocery bag and tie my pull string to it. I use the nylon pull string from the electrical isle at lowes. Then use a shop vac to suck the plastic bag/pull string through the pipe. Being that your pvc is probably below water level, I am not sure if that approach would work since there will be water in the pvc. Same general idea as Pat gave you but suction vs pressure to get the object/bag through the pipe.
You can - be prepared to get wet if you think there’s water in the line.Nice. I guess you could make an "elbow" that screws into the pool-side outlet and brings the pipe above the water line?
Be very careful trying to pull electrical through water plumbing. Those hard 90s will be a issue. Its very easy to get stuff stuck. Old electrician's saying, "God and an act of congress can't pull past 3 90s." Even in those videos, where they are saying "pipe" they are talking about conduit with its sweep fittings, not water pipe. You might get a pull-string through using the methods recommended, but the electrical cord that goes to a lighting fixture is not the same.Going to repurpose a vacuum line for a screw in pool light. Need to fish a new line down it but there are a couple tight bends a normal wire fish won't go past.
