All,
I just performed my first test with the TF100 and wanted to as a few things. Also this is after converting from tabs to SWG about one week ago.
1- is the only PH test with the OTO kit?
2- my CYA seems a bit high. In fact I think it is around 100 but since there is no lines below that on the vial it could be more like 110. I can let some water evaporate but any other thoughts.
3-I have recently been running the SWG on 80% for a 33k gallon pool (circupool RJ60+). Today I lowered it to 75% but wondering your thoughts based on my CYA/FC levels.
4- anything else you feel mentioning based on my first test results
The Oasis
Build Type: Vinyl
Volume: 33000 gallons
Latest Test Result Summary:
FC: 9.0 (40 minutes ago)
CC: 0.0 (40 minutes ago)
pH: 7.7 (40 minutes ago)
TA: 90 (40 minutes ago)
CH: 300 (40 minutes ago)
CYA: 100 (40 minutes ago)
SALT: 3400 (40 minutes ago)
TEMPERATURE: 85° (40 minutes ago)
The Oasis
Build Type: Vinyl
