- Jun 22, 2014
- 52,024
- Fiberglass
- CircuPool RJ-45 Plus
This applies only if you have a large-sized light that is set into a hollow niche. The smaller niche-less LEDs lights do not require removal. The larger light usually has one screw at the 12 O'clock position that holds the retaining ring in place. Once the ring is removed, you can usually pull the light bulb fixture completely out and set it up on the deck so that you can clean in the niche. Make sure power to the light is OFF.On the light, do you mean around the edges of the light cover? Or are you saying disassemble the light altogether?
