Ok short back story. We survived Hurricane Mathew and I clean the pool out and left for work (Gone about a month). Wife was able to keep pool vacuumed and PH&FC in check. Well until about a week before I came home. Pumped sucked air and trying to explain how to prime the pump over the phone with a new little one in the back ground was out of the question. Told her to just unplug everything and I would get to it when I got home, what could go wrong right. HA got myself on that one. Well I got back and needless to say there was a think green layer of algae on the bottom and FC was 0. Here's where I shot myself in the foot. I'm still using the stock manual vacuum head that came with the pool. The water was crystal clear when I started (everything had settled to the bottom while I was gone) but after I was done stirring everything up vacuuming and getting the little amount of leaves out I'd say I effectively stirred up and broke up what was on the bottom and diluted it in the water, ending up with a green pool. Brought the pool back up to my normal FC-8 and let it ride for a few days. Vacuumed and brushed everyday with about a 5FC drop in 24hrs. Water temp is around 56-60. Well that wasn't working so I brought the FC up to 15 and continued on vacuuming and brushing. Seemed to be working and then just kind of leveled of and stayed about the same. So today I went and got more bleach to hit it hard. Pool math said FC28 for shock and 38 for mustard. I'm now at 41 little high due to a heavy hand but has held for the last 4 hrs at that. How long will it take before I see a real difference? I want to say it's working but that may be me being antsy.
Thanks in advance
Thanks in advance
