First time SLAM and very impatient wife!!!
chubrok
12
Chicago, IL
I guess not… I just tried doing a sample with three times the amount of sample water and five drops of the reagent R-0600 thinking that maybe it would multiply out to roughly CL 15 MAX. The color sample was well above the 5 ppm display. So I just added another 32 ounces of 10%… I’d rather error on the side of caution and over chlorinate until my reagent refill arrives tomorrow.
chubrok
12
Chicago, IL
Think I’m getting close. Only lost 3FC last night and tonight’s test shows 0-.5 CC. (Very little if any at all). Water is crystal clear. No debris. At 16FC now. Every mornings overnight test seems to get better & better. This site is filled with amazing information. I can’t thank you all enough for your help and encouragement.
chubrok
12
Chicago, IL
Feeling that I’m nearing the end of my slam I did a 25 mL test in addition to the 10 mL test and get drastically different results… 25 mL test showed CL of 11.4 and 10 mL test showed CL of 14… Am I doing something wrong? Or should they be that far apart
mknauss
23,568
Laughlin, NV
They should not be that far apart. But a 25 ml test with that FC means a lot of drops. And all it takes is a variation in drop size to make a big difference.
Stick with the 10 ml sample.
Reactions: frogabog
