Hello everybody,
So I serviced my water today for the first time. Tested water, here are the results:
FC = 0.5 not surprising since the pool guy has not serviced the pool in over a week and there were no chlorine tabs left in the floatie
CYA = 100 could not see the black dot before level even reached half way to 100
CC = 0.5
TC = 1.0
pH = 7.2
TA = 130
CH = 1625 southern AZ, hard water, so not a big surprise
I added two pounds of Cal-Hypo. The calculator said 2 lb, 10 oz of 53% Cal-Hypo but I used HTH Advanced Shock treatment, which is 56.44% Cal-Hypo, so I figured I'd use less.
Since my CYA and CH levels are so high, I am guessing I should stay away from chlorine tablets and Cal-Hypo for a while, and use liquid bleach only. The companies that serviced my pool were using chlorine tablets every week for the past year, so I figure that explains the high CYA.
Calculator also recommended adding Borax to increase pH, which I am planning to do, just need to go buy some.
Does this all make sense?
Thank you
CC = 0.5
TC = 1.0
pH = 7.2
TA = 130
Thank you
