- Oct 31, 2021
- 36
- Plaster
- Jandy Aquapure 1400
Hi Everyone,
My name is Joshua. I just moved in to my new home I live in Austin Texas. It has a 16000 gal saltwater pool.
I would like to start to learn how to properly maintain it. This place seems to be a great with a lot of people who is willing to help. I am glad I found here.
I got couple of questions and really appreciate if someone could help.
1. I have the pool water tested at Leslie's and the report showed the PH is 8.0 which is high. But I have some test strip bought from Amazon, and it showed the PH level is within the correct range. I tested more than once at different time of the day. So which one should I believe?
2. For the saltwater pool, it has the Jandy chlorinator running at 75%, can I still add some Clorox trichlor tablets using the slow release floater?
3. Since the previous owner did not add any cyanuric acid to stabilize the chorine, the cyanuric acid level is very low. Can I add some trichlor tablets with stabilizer in it?
Thanks in advance,
Joshua
Thanks in advance,
Joshua
