- Jun 22, 2014
- 52,069
- Fiberglass
- CircuPool RJ-45 Plus
Re: TF-100 Test
Your most immediate concern is the 0 FC. So use the Poolmath calculator to calculate how much bleach to get you to a target of 8 FC. If you don't know how I got that number, please see the Pool School - Chlorine / CYA Chart so you understand (for the future) what FC you should be at based on your CYA for a non-SWG pool. That's very important to keep algae away.
After that, please run a pH test and post that for us. Your pH should be somewhere between 7.5-7.8.
Let us know if you have any more questions.
At some point, see if you can add your pool size (in gallons) to your signature. It will help us if we need to run numbers on the calculator for you.
How 'bout this weather huh? Awesome or what! :sun:
