Public pools normally have zero CYA. FC at 7 with zero CYA is an extremely high active chlorine level. Everything changes when you have CYA in the water, which binds to most of the chlorine and effectively holds it in reserve.
Why should it be illegal? They are not allowed to be used for testing most commercial/public pools, but you are not legally required to test your pool at all. What you do with your pool is similar to how you cook in your kitchen. You can leave a chicken out all day in the sun, have its juices on the counter when you then slice vegetables, etc. and the government doesn't care. It's only in restaurants where such practices are strictly prohibited and serious fines or even jail (for serious negligence) are possible.JesseWV said:It should be illegal to sell them if they're so inaccurate.
It all depends on the CYA level since it is the FC/CYA ratio that determines the active chlorine (hypochlorous acid) level. Now that said, you don't want to drink large quantities of that pool water since the FC is what matters in terms of chlorine capacity. As for public pools, the maximum FC varies by jurisdiction with the highest being 10 ppm. The EPA has a maximum of 4 ppm for drinking water, but many jurisdictions allow higher than that for pools. Unfortunately, no jurisdictions that I know of properly regulate the FC relative to the CYA level.JesseWV said:Seriously? Swimming in 20ppm is safe? How can this be? I've read that it's illegal to have more than 7ppm at public pools in most states.
I see your point. People could not test at all and swim in a cesspool if they wanted to.chem geek said:Why should it be illegal? They are not allowed to be used for testing most commercial/public pools, but you are not legally required to test your pool at all. What you do with your pool is similar to how you cook in your kitchen. You can leave a chicken out all day in the sun, have its juices on the counter when you then slice vegetables, etc. and the government doesn't care. It's only in restaurants where such practices are strictly prohibited and serious fines or even jail (for serious negligence) are possible.JesseWV said:It should be illegal to sell them if they're so inaccurate.
I've shopped for thermometers and seen some that are way off (though not 30ºF), but what keeps them from being ridiculously far off is that people would stop buying them or would take them back to the store for a refund, etc. For water test kits, there are inexpensive ones that aren't as good and more expensive ones that are better. You are responsible for picking the one that you want.JesseWV said:It's like selling a thermometer that is off by 30F and saying "They aren't allowed to use those thermometers in commercial food storage refrigerators, so it is acceptable."
The office or bureau of weights and measures or division of measurement standards, which varies by state (and sometimes by county), is about commercial weighing and accuracy, so scales as well as some metered output such as gasoline pumps or taxicab meters as well as product labeling such as net weight of food items. That does not apply to most consumer products including water test kits. About the best you could do would be to sue the companies for any fraudulent claims as to being an "accurate" test kit, but unless they make a specific accuracy claim that they are missing, you'd have a hard time winning and quite frankly anything less than a class action lawsuit would not have enough "damages" to justify the legal expense of the action. The low resolution of the test strip products I took right from pictures on their bottles -- they aren't hiding that. It's the even lower accuracy for some of the tests that isn't explicitly disclosed.JesseWV said:It seems to me that a product intended to measure should be regulated and tested by some department of weights and measures somewhere?! Right?
duraleigh said:I scanned this thread briefly.
When you get dirt coming back into the pool after backwashing, are you placing your multiport valve on "rinse" before you return it to "filter"?
thepiratemorgan said:Listen Jesse, I know your wife put the kabash on your test kit order, but I can attest to the necessity of a good test kit....... ......I highly recommend the TF-100 kit, nicely prepared and full of testing supplies. I highly recommend the BBB method, and I highly recommend the "pool calculator". When you practice and use all three, being the "pool boy" is a breeze ... now on to mixing alcohol chemicals instead of pool chemicals and the "bar keep" is open for business!!
You are correct. A clarifier or flocculant is a last resort after addressing other more basic circulation or filtration issues which usually clear a pool. See Add DE to a Sand Filter for instructions. If you did add a flocculant, then normally one turns off the pump to let precipitate settle and then carefully vacuums to waste that which settled. If you mix all these things up (i.e. clarifier, flocculant, chlorine/circulation/filtration methods) you're just going to make things worse.JesseWV said:I'm thinking I shouldn't even attempt using a clarifier type product until I get the gasket in the Vari-flo valve replaced and maybe even put some DE in the sand filter to boost filtration. How much is a good amount to add?
JesseWV said:Well thanks to some good luck and a promise to take my wife out to a nice dinner I was finally able to get a TF-100.
JasonLion said:Simply using more pool water does not change the reading, it just makes the color more difficult to read. You need to mix pool water with chlorine free water (perhaps distilled water) to read higher levels. This works to some extent up to about four parts chlorine free water to one part of pool water (multiply the result by five), but you lose a lot of precision.
