- Jul 23, 2024
- 44
- Fiberglass
- Hayward Turbo Cell (T-CELL-5)
This is my first time opening my pool. The installer is coming to open it up in 4 days (replug salt water generator, remove plugs, etc) but they do not do the water chemistry, so I decided to do it myself.
I work from home so I can closely monitor it.
The pool is very dark green.
I am in Canada (Montreal) so we had to wait this late to open because spring came here late.
I have found good guides on here to open to a green pool but I have a few specific questions.
1) I do not have a vacuum to waste option. I have 2 filters (1 used from last year and 1 new).
I was thinking of using the used one for opening the pool and then using the new one for the rest of the season.
Will the filter be able to filter a green pool like this? If not, I have a shop vac, I also have a transfer pump (plug my regular hose on it to empty a bit the pool sometimes or to empty ponds).
Was also thinking of buying a cheap pump and creating a portable vacuum. Might be overkill haha.
2) my other question is:
Should I do a full test with my Taylor kit while the pool is green like this? Where do I start? When do I start testing?
Thanks!!
Thanks!!
