- Apr 19, 2019
- 331
- Vinyl
- Hayward Aqua Rite (T-15)
Hey all,
ive read everything available on closing the pool, but I have a few questions.
- do I just drain the filter? and should I add antifreeze to it?
- I plan on blowing all my lines out but I’m not sure of how much antifreeze to add. The pool school article says 1 gallon per 10-15 feet. That seems like a lot more than my pool guy added when he closed it last year. If I blow the water out is it really necessary to add that much. My furthest return is probably a 50’ run. That’s 4-5 gallons and then the skimmer is close to it that’s another 4-5 gallons. at $4 a gallon, the cost is going to add up quick. Probably still a bit cheaper than the $375 my pool guy wants but I just need to know how many gallons is really necessary if pipes are well blown out.
- my waterfalls. Will get blown out and have antifreeze put in them. Is that enough to protect them?
- pool guy stuffed empty antifreeze bottles into our skimmer. What was the purpose of that?
- I have a bunch of screw in plugs for the returns and the skimmer holes. Teflon tape is enough for the threads, right? I also have some rubber plugs for the spots that don’t have a threaded opening.
- do I leave the pump connected or disconnect it from the pipes and plug them?
ok. I think that’s it for now.
thanks everybody.
thanks everybody.
