If you can plug the hole closest to the pool in the bottom of the skimmer with even a rag and add the solution with the pump running you won't have that problem. That port is an equalizer port that, if there is a float valve in the skimmer will allow some water to be pulled in through it and, if the water gets too low, allow the pump to get enough water to not be damaged.
