I got my kit today and ran a full battery of tests for my new plaster pool.
Here's the log:
I'm currently running trichlor pucks and have been since startup a few weeks ago. Three pucks to be exact and they have not been dissolving very fast on a setting of 5 on the Pentair Chlorinator. I am shutting it off and pulling them today and switching to just 10% liquid chlorine.
Water Temp 90* F
OTO CL - 0.5
pH - 7.8 - 8.0 ? I logged 8
FC - 0.5
CC - 0
TA - 90
CYA - 20? 30? Dot never completely disappeared and I ran out of water between 20 and 30. I recorded 30 to round up but 20 may have been more accurate.
CH - 350
Obviously FC is low. Based on the CYA Chlorine chart I am going to target FC of 6. Per Pool Math I need to add 3 quarts, 2 cups. I will be doing that now.
pH has crept up from last week but has been keeping around this level. Pool math tells me to add 1 qt, 1 cup to lower pH to 7.2.
I have a spillover and kids splashing so I should have plenty of aeration to raise pH back up.
I also need to add CYA.
TL;DR
Plan
Thanks all!
Here's the log:
PoolMath Logs
api.poolmathapp.com
Water Temp 90* F
OTO CL - 0.5
FC - 0.5
CC - 0
TA - 90
CH - 350
TL;DR
Plan
- Remove trichlor pucks from Chlorinator
- Add 3 qt, 2 cup of chlorine to pool now
- This evening add 1 qt, 1 cup of Muratic Acid
- Test FC, pH, TA tomorrow
- Find CYA tomorrow
- Does this plan look reasonable?
- My CH tested from Pinch-A-Penny last week was 195ppm. Should I trust the CH result I got today?
- Liquid vs granular stabilizer?
Thanks all!
