So just to summarize the situation: I recently took over a pool in a new home. Pool was refinished about 7 years ago. Recently cleaned the roof and removed some large redwoods next to the pool. This put a lot of stuff in the pool, which I managed to take out and clean up fairly quickly. But somewhere around that time I noticed these stains and marks show up on the pool walls mainly, but also in the steps (Pictures below).
I cleaned my filters couple months ago following all the debris that went into the pool and noticed some brown staining on them. My strainer basket and that whole area also has had some crazy brown staining on it as long as I remember (pictured below).
My CYA was at 180 and I think previous owners just used pucks to treat the water so I just did a no drain water replacement which took some time. My test levels from today:
FC: 6
TA: 70
PH: 7.8
CH: 250
CYA: 50 (rounded up)
So today I balanced my levels to what you see above. After lots of reading and learning about stains, I started with the puck test and that did nothing to the stains. So I got some vitamin C, making sure it was pure absorbing acid, crushed up about 20 pills in a sock and tried that on various stains around the pool. That did nothing. I’ve been brushing as much as I can with a basic pool brush and that has done nothing.
So now I’m at a crossroads and I’m looking to figure out what to do about these stains or marks on my plaster. The pool guy I had before mentioned an acid wash as an option to get rid of the stains. This idea has been a last resort option that I’m hoping to avoid, but if it’s my next step then I guess I have to do it.
I will say the water itself looks much better, but those stains suck!
