Thanks. So it sounds like I leave it where it is unless my chlorine gets low? It also says it takes 24 hours to register after adding salt. I wonder if that's 24 hours of it running. Since I don't run my system 24 hours a day.
It will take some trial and error to dial it in. I would like to point out that right now it isn't producing any chlorine so you will need to test and add bleach to keep the FC up. Once the unit starts, you will still want to test the FC daily and see if the setting is enough to maintain proper FC levels or if you need to adjust the setting. This will be an ongoing process because as the temps go up and chlorine demand increases, you will have to make sure the FC levels stay up to par. Please don't get lax with the testing, it is lower maintenance, but is not a " set it and forget it" system. As you learn your pool and its needs, you can cut back on some testing. But for now, stick with daily testing.
I don't think you said which model you installed, but you may want to bump it up to 40% to start with and then turn it up or down from there
The internal salt check should be daily, not once every 24hrs of running. If it doesn't start by tomorrow morning, I would turn the power off and back on to reset it. From the manual, pg16 under "Sanitizer Output Settings and Adjustments", first bullet talks about initial startup salt check.
"Switch on the pool pump switch or pool pump timer. The salt display will blink both LEDs (bottom totop) for two (2) minutes, indicating that it has not checked the salt level yet. After two (2) minutes, the salt will be checked and one (1) of the salt level LEDs will be displayed."
