Ok my tf100 kit came in and I tried my first series of tests
My water was initially balanced by a pool guy who did some repair work on it (bought the house a month ago) after we filled it. He put in three smaller size containers (looked like 4lb containers) of granular stabilizer, big bag of calcium bicarbonate, half a big bag of calcium chloride and 4 trichlor tabs.
I was just using strips until my test kit came and after a pool party we had last weekend I put a gallon of 6% bleach in. That's the total amount of chemicals that have been used so far.
The first couple test were straightforward and easy
pH in the mid 7 range using the color block thing
FC 3.5
CC 0.5
CH 150
Looks like maybe I need to add baking soda and a gallon of 6% beach?
The TA test I am a little unsure on. Are we supposed to stop adding drops when it initially flashes red. At 9 drops the water would flash red and immediately go back to green. It did this for the next few drops until at 13 drops it stayed red. Which # of drops do I use for a result?
And then the CYA test seemed like a real problem. Is the dot supposed to completely disappear or just look like a whitish dot? I think I got either 20 or maybe 30 as a result....but it still seemed like I could see that cloudy dot even then. I bought the standard solutions and even using the cya one which is supposed to be 50ppm I seemed to get in between 30 and 40 (closer to 40 though) so I must need work on my technique. Is the sliding dot type cylinder worth getting for ease of test results? I know it uses more reagent but if it's easier to use and gives me more reassurance in the results I'd be willing to pay if it's just like another $40 or so a year in test supplies.
FC 3.5
CC 0.5
CH 150
