Cl - out of range, pH 8.2
FC 10.5 CC 1.0
TA 210
CH 1000
CYA 100
pH meter result 7.98
Entered number into PoolMath. Recommendation:
- to lower pH: add 111 oz of 14.5 muriatic acid. Can I add this all at once? Directly into the pool or into the skimmer basket?
- to lower TA: reduce pH to 7.0-7.2 with acid, then aerate to increase pH to 70. How do I aerate? Running the waterfall?
- to lower CH and CYA: partially empty pool (57%) and add new water. Since the last time I researched this, I saw there are some companies that will pump and properly dispose of poolwater. I saw on this site that process this is not recommended until temps are 85F and below, so I will have to wait with that until then.
We just received a shipment of muriatic acid called acidblue that we ordered online before we came upon this site and learned to avoid pool chemiclas with blue in the name. Can we use it and never buy it again, or should we use it to clean the driveway and buy a different product for the pool?
FC 10.5 CC 1.0
TA 210
CH 1000
CYA 100
