aeh0603
No dilution is needed to do what you are trying to do. If you have a way to measure out a 5ml sample of pool water, just use that (without dilution), add one scoop of powder, and each drop is 1 FC. You loose some accuracy, but it's good enough for most of the slam. Just go back to a 10ml sample for the OCLT when you get there.
As others mentioned above city tap water usually contains FC and could also contain CC, so if you have testing this way for a while it is likely skewing your results.
