Greetings forum members, I found my way here after another member had their pool installed last year, and said that he was using the recommendations here to maintain his pool with good results. Our 4- year old AG vinyl pool was just paid off this month(Yay
), and we've had good luck over the years using the BioGuard products from the store, with our chemical budgets not being outrageously expensive; except the one time when we had an algae outbreak, and that was due to neglect on my part. I forgot to change the automatic Frog Leap chlorinator pac while "life" happened. I'll preface my post with saying that we usually keep the FC to 0.5-1.0 for maintenance, and turn it up when it gets more usage or the dogs get in. Considering the chlorine shortage that I've read about, and the reports that having a dog or 2 in the pool is the equivalent of 30 people or so, the dogs probably aren't getting in this season.
This year, I removed the cover to find mostly clear water, but hazy. The ever-present pollen ring around the rim was there. The past few years, there's always a boatload of pollen that seems to indicate what the water level was ranging between. I circulated the pump and filter for 48 hours before I took the water into the pool store to have it tested. The water had a cloudy look to it, and I saw that there was a lot of stuff just floating 'round, like there was a lot of particulates in it. It looked more hazy that I remember, but not sparkling like it used to be; granted we had just opened the pool, and I hadn't even started vacuuming yet.
The test results from the pool store showed the following:
pH 7.4
FC 0.1
TC 0.4
TA 89
CH 147
CYA 97
Phosphates 3348
My preferred salesperson at the pool store said about the phosphates being high is "this is something that they've started asking us to test for, but you shouldn't worry about it". Out of all of the employees there, I trust her the most; she's the one who sold us the pool. Especially after we had another employee sell us a metal sequesterant after we introduced our algaecide that was copper-based after opening. She told her "They don't need that, why are you trying to sell them something they don't need?"
The recommendations were to add 5.5# of Balance Pak 100 (Sodium Hydrogen Carbonate), and adjust the pH down with 0.75# Lo 'N Slo (sodium hydrogen sulphate + sodium sulphate) and about 4 oz of Natural Clarifier. I did not have any BurnOut 73 on hand, but I did have Smart Shock (63.05$ sodium dichloro-s-triazametrione + copper citrate). I had most of the chemicals I was going to need at the house, with the exception of the torpedo pacs (chlorine) the mineral cartridge, and the algaecide. When I got home, I installed the mineral cartridge into the automatic chlorinator, and the bottle of algaecide that we have used for the past 3 years and let that run while started adding the Baking Soda, and going through the routine over the next day of letting the chemicals do their thing over the opening days. On day 2, I figured since I had 0 chlorine, it would be ok to add shock, just to prevent any bloom since my FC was nonexistent, so I added 1# of smart shock. The next day, I noticed that the pool was getting more hazy, and wasn't clearing up after 48 hours of continuous pump running. I used the "guess strips" and saw that my FC was 0, and I figured most of it had probably been consumed by any algae that might be present, and what I was seeing was just an abundance, as I was vacuuming up stuff off of the floor of the pool in the AM before the pump was running. Over two days, I had brushed all the walls, and vacuumed the pool multiple times, and wasn't getting any clarity.
I did have the new torpedo pac installed in the chlorinator, but it didn't seem to be making much progress in keeping the chlorine elevated. I also assumed that there was an abundance of "stuff" that needed to be killed in there because I started fishing out and killing more backswimmers/boatsmen the day after opening
I figured I had opened a buffet for them. So I added 20 oz of 10% sodium hypochlorite, which is a heck of a lot less expensive than those torpedo pacs!
Today, my test kit arrived, the water is still hazy, and I've vacuumed it 5 times since I opened. Seeing more aquatic insects than I'd like, and got some pretty eye-opening results, with suspicions on what guidance I'll receive.
pH 7.5
FC 1.5
CC 0.5
TA 160
CH 1000
CYA 100
Out of curiosity, I tested my CH again, and it was correct. I suspect with the calcium levels being that high, and my CYA being so high, a water change would be recommended, per the pool math page. I tested our source water, and it has a FC of 2.0, CH of 200, and CC of 0. TA was around 200.
So, that's where I'm at right now. I can call the city, and have them hook up to the hydrant that is right in front of my house, and fill my pool for a flat rate of $100. I just wish there was a way to use some of the water that's in the pool to irrigate my crispy lawn. I do have a submersible pump with about 150' of garden hose!
pH 7.4
FC 0.1
TC 0.4
TA 89
CH 147
CYA 97
Phosphates 3348
pH 7.5
FC 1.5
CC 0.5
TA 160
CH 1000
CYA 100
