- Jun 11, 2024
- 88
- Fiberglass
- Hayward Aqua Rite (T-3)
Hey guys,
My water is well above the skimmer and I’m pre planning what I may need to do regarding the chemistry.
1). Should I just syphon water out with standard garden hose or should I use the filter somehow I.e. drain it to waste with the rubber rolled up hose? What’s the process for that?
2). I have a SWG and my chlorine has been running around 2-3 ppm…..I expect it to be lower. Also my stabilizer is over 100 ( that’s how they set it up when they installed pool). I assume my CYA will drop a bit after draining water. Currently I have swg at 40% and running for 9 hours.
3) if chlorine is very low should I add bleach or liquid chlorine? What is the preferred choice? Sounds like TFP doesn’t use powder shock.
Pool is 10x20 fiberglass
Thanks for help. I want to get right on this
Steve
Steve
