Greetings from Charleston, SC. Received my first quote for an IG pool. Might be the only one I get since these companies are swamped with requests during these strange times.
Here is a link to my backyard Backyard looks bigger than it actual is since my property line cuts at an angle. The HOA has already given me their approval to build our future fence over the property line and put it right next to the pond since that is all unused land to them.
Anything stick out to you in the quote below? I'm waiting to get a fully itemized quote with the specific equipment included. I'll update this thread when (if) that comes back. Also, please feel free to pick apart the design picture I included! I'm slightly worried about the pool feeling small since in certain places it will only be about 11-12' wide. Anyone with a similar design/size that can chime in? We don't really plan on hosting many people here so it would typically be used by my wife, myself, and our 2 kids ages 6 and 2.
POOL SPECIFICATIONS
• Pool size: 16’8” (Width) x 32’1” (Length) 392 Sq. Ft.
• Water depths: 3’6 shallow end up to 6' deep end
• Choice of frost proof 6x6 waterline tile
• Excavation with dirt removal from site or spread around site if needed – clean up construction site
• Standard skimmer, returns, drains w/plastered lids and hydro static valve
• 2” Scheduled 40 PVC plumbing lines, pressure tested, 30’ plumbing included w/necessary valves
• Deluxe vacuum and cleaning tools with initial startup kit
• 1x Dedicated well head under pool for standard de-watering during excavation process
• Up to 2 loads of stone gravel base for water management under pool shell
• Premium grade 60 steel rebar • Shotcrete 8” structural walls and floor at 4000 PSI application with 10” bond beam
• Building permits and construction drawings
• Startup and familiarization of pool and equipment
• Luna Quartz ‘Martinique’ interior finish with 10-year surface warranty
• Lifetime warranty on pool shell
• Workers compensation, general liability and property damage insurance included
• 1-Month (4 weeks) weekly complete service package (chemicals/cleaning) – only available in-service areas POOL EQUIPMENT & ELECTRICAL (3-year warranty on all equipment) – Pentair equipment
• Energy efficient variable speed pump – includes frost protection
• Cartridge filter setup / Includes 2x LED light package
• Salt system w/advanced automation package – monitor pool from iPhone/android/pc
• Concrete equipment pad (2.5x5) Approx. / Electrical allowance up to $750.00
* SPA SPECIFICATIONS:
• 7’x7’ raised built in spa to include: 3 Ft wide spillway, 400k BTU heater (gas line by others), 1x LED light, blower, 6x therapy jets and plaster drain lids – Upgrades included: cartridge filter, intelliflo pump, paramount 360 drain
*DECKING FEATURE
• Includes travertine bullnose coping
• Additional concrete 785 Sq. Ft.
• Steps / Sun shelf w/ bubbler
• Deck Drainage – Transition from pool area and house
PROJECT TOTAL $73,850.00
ITEMS NOT INCLUDED Door alarms per code, temporary water, power or fences, gas and water supplies, fencing or railing, stands for heaters or required engineering for stands, v-zone forms, cat5 line for automation systems, landscaping or irrigation, adequate fill dirt, survey or drainage plans.
Thanks for reading!
POOL SPECIFICATIONS
*DECKING FEATURE
Thanks for reading!
