- Jun 22, 2014
- 52,193
- Fiberglass
- CircuPool RJ-45 Plus
Hu Lula! Well, no doubt that your current FC is low, and I suspect that is letting the algae return - especially in warm/humid Miami. You know how to SLAM, so knock that out first and make sure you pass the 3 criteria. After that, continue to check your CYA every week or so for about a month. Do this to instill constancy and check for CYA reduction based on water replacement. Right now you're showing a CYA of 35 (round-up to 40), so your FC should be 5 (SLAM FC of 16). I doubt your dog has anything to do with it. Woof! So wrap-up this SLAM and keep that FC a bit higher.
Oh, please lower pH slightly (7.2-7.5) before starting the SLAM.
