Looking soooo pretty!!!Looking more blue but cloudy. Chlorine and Calcium chloride added today. Start-up guy will be back once or twice next week then it's on me He said I should check Ph on Fri or Sat and add MA if needed. I'll be checking everything tomorrow, not going to wait until Fri.
The PB wanted this guy to look at the lines I keep complaining about in the plaster (not sure why, not his area of expertise) but he looked and I asked if the lines were normal...he just threw up his hands and said, "I'm not saying anything." So someone else is coming out this afternoon.
Wait... *Garagemahal*? Sorry Kathy, I'm officially hijacking your thread. I need pictures.With all the things we've done to our home in the last few years (pool, garagemahal, hurricane windows) our plan is to be carried out feet first.
Seconded !!!officially hijacking your thread. I need pictures.
No...and I had pointed them out to the guy and he said, "no problem, I can take care of those." Well he finished, started filling and took off and my PM ignored my texts asking about it.That color is looking much better already.
Did they not patch the lines when they did the acid wash? I forgot to ask about that.
Well you are almost there and the final details can feel like infinity. Since you did not get the autofill, is your only option to add water is via a hose?Looking more blue but cloudy. Chlorine and Calcium chloride added today. Start-up guy will be back once or twice next week then it's on me He said I should check Ph on Fri or Sat and add MA if needed. I'll be checking everything tomorrow, not going to wait until Fri.
I'm getting autofill...I'm not giving in on this. Oh, I must not have posted the final drawing. Look at my avatar...that's more accurate...going to put plants next to the shelf, the bowls will be on the 2 center pillars and then deck jets will be on the other 2 (I will probably barely use those and am thinking I will actually put some plants there).Well you are almost there and the final details can feel like infinity. Since you did not get the autofill, is your only option to add water is via a hose?
I went back and looked at your original drawing and the bowls will be on each side of the Baja deck. What will be in those 4 raised sections on the left of this picture where there is white pipes?
The water is definitely less green but it will get much better with a fully balanced water, continued circulation and as the plaster dust is captured by the filter.
Thanks for the update.
Let me know how adding autofill works at this stage of the build. I'd like to have autofill and drain, but assumed it was too late.I'm getting autofill...I'm not giving in on this. Oh, I must not have posted the final drawing. Look at my avatar...that's more accurate...going to put plants next to the shelf, the bowls will be on the 2 center pillars and then deck jets will be on the other 2 (I will probably barely use those and am thinking I will actually put some plants there).
The whole build has felt like infinity, haha...I have a list of like 15 things to still be done...I'm trying to tell myself to chill out since I can actually use the pool now but I just want to be done, lol.
One idea is to consider repurpose one of your deck jets to a fill line. It would take some rework on the equipment pad and may have to modify the pillar. But if you do not plan to use the deck jet then get credit on them to get the auto fill if that is more value to you. You can make a scenario that you “really want” the deck jets but you will give that up if they can make an auto fill assuming they give you credit for the deck jet and also the auto fill since you are “giving up” something to fix something that they should have done. I think you have some leverage to get it done. The alternative may be tearing up your deck and that may not be great.I'm getting autofill...I'm not giving in on this. Oh, I must not have posted the final drawing. Look at my avatar...that's more accurate...going to put plants next to the shelf, the bowls will be on the 2 center pillars and then deck jets will be on the other 2 (I will probably barely use those and am thinking I will actually put some plants there).
You can start testing, and if something is way off base (pH super high or low, chlorine low or CCs > 1) ask your PB or his startup guy about it. Just demonstrating that you know how to test and are tracking water chemistry closely may lead to higher quality start up from your PB. I recommend letting them add the chemicals for now, and being ready to take over on day 30.From my reading on here, if you can smell chlorine it means there's something wrong...does that mean you shouldn't smell chlorine at all or can you smell a light amount? The pool hasn't been turned over to me yet so I didn't want to just start putting chemicals in and messing with the start-up guy's process.
Newdude...you are assuming that they test, bahaha...so far they have just thrown stuff in (at least from what I saw)...that's why I'm afraid to mess them up, lol.+1. You have to let them handle it for warranty purposes the first 30 days. However. If they happen to show up and your PH/FC/CYA is already good, Well look at THAT. Either you are lucky or one of his crews musta came when you weren’t home and balanced it. *wink wink*.
OMG, no way I could schedule a pool party so soon, lol.Our guy may have tested. But he only came out once a week, and his instructions to us were to sprinkle a pound of Cal hypo every other day (ish- as memory serves) and pour in a third of a gallon of muriatic acid twice a week. I didn't have my test kit yet so I wasn't doing my own testing until right at the end of their startup. Precise to TFP standards it was not. But the folks here helped me get it sorted as soon as the pool guys were done.
I went back and found my panic post from 2019. Pool builder had in theory been taking care of the pool, and I tested in advance of a big 4th of July party. Thread 'First day of all salt... low chlorine, low ph.. help!' First day of all salt... low chlorine, low ph.. help!
As you can see, the great folks here got us sorted.
