Am I imagining things or is there an issue with this? Also, can I change the default of 5ppm fc to 7 or whatever number I choose so it auto populates as the default? Thanks
I think you may be confusing a couple of things, or I'm confused with your explanation.
IGNORING notes/expenses/maintenance, there are two things you can log, Chemicals and Test results.
There are two ways to log chemical additions
There is one way to log test results.
Starting with logging test results, you click on the + button, select "log test results" and you will get a screen that allows you to enter your test results. There is no default to any test, you simply enter your results, click on the check in the upper right hand corner and your results are saved. I don't think there is a way that any "default" for test results can be saved.
Chemical additions can also be logged by pressing the + button, and select "Add Chemicals." Here too, there is no default, you simply select what you are adding and the amount. Again, click the check to have it save.
The other way to add chemicals is on the home page where you see all of your current test results. Click on FC and you are presented with a screen that includes CYA (your current level), a recommended range, a SLAM slider and a box with "Current" FC value and a "Target Free" value. The CYA comes from your last logged CYA level. Your Current FC comes from your last logged FC. The Target Free is populated based on your CYA level and the Chlorine/CYA chart. If you change your CYA value at the top of the screen, your Target Free will change. That is where your target free comes from. If you select a sanitizer, then you can log the addition of the chemical from there, but it does not save any FC TEST VALUE, it only saves the ADDITION OF THE CHEMICAL.
I hope that helps!
