Hi guys and gals!
First off, I want to say thank you for the wealth of information here. This site has made me much more confident that I can maintain my pool myself and on a relatively tight budget. Thus far I've picked up the TF-100 and have been using that to get everything balanced. I also subscribed to the Pool Math app which has been pretty helpful. My pool has a spa attached, and that is where my first questions to you all come in.
The pressure coming from my return jets in the spa is very low. I have to turn my pump up to 2850 rpm to even get a tiny bit of water flowing through them, close to maximum on my pump (kinda defeats the power savings of a variable speed). I think the problem here is twofold. First, the jandy valve is installed improperly, as I can't turn it to shut off the pool. It'll only turn to shut off the water coming out of the heater (bad) or the spa. Seems I should be able to take it apart and rotate that, right? The way it is set up now I can't run the heater to just the spa, and the valve is likely blocking the flow from going evenly into both return lines. See pictures attached if it helps (sorry, the only picture I have of the pool!).
The second part of this is that the return line to the spa has a much higher section just off the junction I'm talking about above which I'm sure is causing water to not flow evenly to both pool/spa as it would need a lot more pressure to get up that additional foot or so. That spa line has a backflow valve on it, so I don't see the point in this. Crappy thing is - before I had any knowledge about pools I had a pool inspector AND a pool tech come out and no one pointed these things out to me.
If my hunch is right and I can lower that spa return line to even with the pool line, I'm hoping there's some sort of basic guide someone can link me to with the parts and tools needed to cut it apart and put it back together. I'm fairly handy but young/inexperienced with home maintenance don't even know what the pipes are made out of
. I do like to try, though!
I have a few more questions but I'll leave it at that one for now since it's getting late, and start asking those in the comments after the part 1 is resolved, haha.
Thanks again for the help.
