First filter clean and SLAM!
CombatVet13
64
Mesa Arizona
I went through my first SLAM, and first Cartridge filter clean since the completion of my first pool Opening Mid July.
Had a pool party this past Sunday, and the following day, I noticed I was going through chlorine abnormally high. Water remained clear etc., but fearing there was something in water, i started the slam yesterday. I brought it up to Slam level twice.
I’ll do the Overnight test tonight to confirm good. After a little over a month my filters were surprisingly very dirty.
Unless you like cleaning filters, which I do not, you can probably go a lot longer between cleanings. They may look dirty, but you have a lot of filter surface area you can fill between cleanings. I'd keep an eye on the pressure rise or once a year whichever hits first.
Once a month will get old really quick.
Reactions: CombatVet13
You'll see what dirty really looks like after a year. :shock:
I've got a wall of trees behind my pool and horrid pollen in the spring, and I don't see much over 5psi pressure rise over the year, so I clean post pollen in the late spring.
