So my pool builder has disappeared close to the end of the job. Phone number is disconnected and I have traced him to TX, I’m in CA.
I would just like to finish off my pool but need the following done
1. Install SWG also need to procure
2. Install my aqua link system ..I have the parts
3. Connect the electrical
Contractor installed the PebbleTech and filled the pool stating they would be out the next day to finish install But never showed. We jury rigged our sump pump to circulate the pool with chemicals after about 4 days but have no way to filter the system. Pool water has been in place for 12 days now .. not sure how long this rigged process will work.
I believe everything else is done except final inspection (which I can handle if necessary).
All installed equipment is Jandy.
Any thoughts or helpful suggestions?
Does anyone have a recommendation for getting another contractor to do this work in Long Beach CA
