I always keep a couple boxes of 20 Mule Team Borax on hand in case I get too close to the lower end of pH. (It never goes bad if kept dry.) Aeration works too, only slower. You are maybe walking the line at 7.0 pH. For SLAM purposes, 7.2 is ideal to start. Note: Twenty Mule Team should have very little effect on your TA.
I asked if you had hoses, because by-passing that heat pump is relatively easy with hoses. With hard plumbing, there's a couple different ways to do it, and makes it even easier to bypass the heater, but you've got a lot on your plate for now w/o redoing your plumbing.
With our pool, I like to take care of issues one at a time, if possible, if for no other reason than that so much of pool care is interconnected. I get confused too easily at my age to have more than one can of worms open at a time. YMMV.
