Rossterman
i had the warranty people come out and he said the clamp failed and also had hairline cracks in top- the threads were stripped where the pressure got to it - guess he knows?! The inside manifold was also damaged - likely over time and not this one issue. He is going to put in for a whole new filter so we shall see what happens. Going to have to figure out something to keep water moving - maybe a bunch of kids in the pool?
Thanks for all of the discussion about this issue for me, much appreciated.
Coach
I have this exact filter (Cl580 which is just a little taller) which is 17 years old. The clamping ring on mine still looks like new. Yours is obviously beyond end of life. As to the internal manifold, these were a weak point and failed on a regular basis. After the 2nd failure, I reinforced mine with fiberglass cloth and resin. They eventually redesigned the part to correct the issue so have the installer ensure the filter has the updated part (being new that’s almost a given). The good news is you will now have clearer water too as the internal leak bypasses filtering the water. Here’s what the old design manifold looks like showing the common failure location.
