Filter ring bolts
Hi,
If its just stuck on or corroded, you can soak it with PB Blaster to get it broken loose. PB Blaster is the best stuff ever for things like that. Soak it and let sit for 1/2 hour or so. Its available at auto parts stores and I think Wal Mart may carry it.
and last but not least, righty tighty, lefty loosy. Make sure your turning the nut the right direction, which is counter clockwise.
Vise grips probably won't grip the center section hard enough, but if you're going to saw though it anyway, it won't hurt to try. So what if the bolt gets all scarred up?
If you don't have a die grinder, or a Dremel, you can buy an arbor (mandrel) for your drill. A cutoff wheel will go through that bolt like a hot knife through butter.
