I am new here and can not get my pump to hold prime. It starts out fine and then slowly fades away to nothing. This has been a chronic problem over the years and I really want to just give up. My frustration level is at 100+!
I have an ABG 13,000 Gal and a Hayward Power Flex DE filter.
I have replaced everything from the skimmer to the return. The motor was replaced at the end of last summer and the filter is brand spanking new. The pressure gauge has been running at 16 psi and goes up to 18 psi as the water pressure goes down. I have not seen it go over 20 psi. I will say that I have not put in the full amount of DE because I feel that would hinder the water flow, but maybe I'm wrong.
There is not one drop of water from the skimmer to the motor. (I'm pretty proud of that!) The connector (the black dohickey) between the motor and the filter was just replaced a couple of days ago. There are little drips on both sides of the connector that I can not get to stop. I'm afraid to tighten it too much. It did come with plumbers tape on it. Should I have replaced that? Are my hoses too long?
It seems like such a simple set up compared to some of the photos I've seen on this site and I don't understand why I can't figure this out.
When I opened the pool it was algae green and now it is cloudy aqua so something is going through the filter but I can't go and prime the pump every hour. No one at the pool store gives a Crud no matter how much I spend there.
Help!
Thanks, Jeannette
Help!
Thanks, Jeannette
