Thank you I will look at that. So I could have an algae build up with new sand? Maybe what I am describing isn't helping it never has run more than 2 hours without the pressure build-up
You have algae in the pool that has not yet gotten to the level of being visible. The filter is doing what it is designed to do, it's filtering the algae out and getting plugged up. You need to kill the algae. To kill it you need to complete what we call a SLAM
We’ve all had to deal with a green pool. Clear algae from your pool with a SLAM! Read here to use shock level and maintain to clear your pool.
www.troublefreepool.com
To complete the SLAM and know what is going on with your pool we need accurate test results we can trust, and those don't come from a pool store. We base our pool care system on your personal accurate testing and only adding what the pool needs, when it needs it. To do that you need your own accurate test kit. Order a
TF100 test kit.
Now, please don't run down to the pool store to get your water tested. We find that many times pool store employees primary goal is to sell stuff, not necessarily get your pool in perfect condition. As to whether that is because of improper training, lack of knowledge or just to sell stuff I will leave up to you. While you would think that a "professional" would be the best, unfortunately in most cases it is quite the opposite. Between employees who blindly trust the word of chemical sales representatives and high school kids working in the pool store for the summer you end up with poor results from their advice and testing.
The only other real option for a test kit is a Taylor K-2006-C. Be careful comparing prices because the K-2006 comes in sizes, designated by a letter. The basic K-2006 has .75oz bottles. You need to get the K-2006-C to get the larger bottles that you want. Even then it is a little short on the reagent & powder for the FAS/DPD test.
While entirely optional, I also have the
TFTestkits.net and
TFTestkits.net . They speed testing and accuracy. The Speed Stir comes as part of the Pro kit.
I have my suspicion that you have never eliminated the algae from your pool, but only and
Overnight Chlorine Loss Test.
How much
Pool School have you read? Start with these:
There are several items things every pool owner should know about swimming pool water. We share details on the basics of Pool Water Chemistry.
Which should I buy? TFP's recommended pool chemicals are cheap, easy, and won't unbalance your pool water.
Before chlorinating your pool, you should know these simple tips. Learn the best way to add chlorine to your pool.
Managing your cyanuric acid and Free Chlorine levels is key to stabilizing your pool. Learn how these two items affect each other.
So, welcome to TFP!!
