Hi, and thanks for the warm welcome.
I wanted to keep this brief (for your sakes!), so I'll do my best. Before I begin, I just wanted to say "Hats-Off" to those of you who care for above ground pools. I had an in-ground in Antioch, Ca., that I cared for for 13 years, and with the Polaris I had, the thing practically took care of itself. But this 10K gallon Splash above ground I have now...Jesus, Mary, Mother of God! It is THE biggest pain in the a.. I HAVE EVER ENCOUNTERED!!! OK, now I've got that out of my system, I can proceed.
Been here in Rocklin, Ca. for 7 years now with my wonderful Splash "Superpool" (really?). The first couple of years were not too bad, other than the fact the pool is surrounded by big trees and is hard keeping debris out. Then at some point, I started having trouble keeping my pressure down. By the way, it's a Sta-Rite cartridge filter system, with a 1 hp Sta-Rite pump, and a system 2 PLM-150 cartridge. The thing was normally running between 10-12 lbs. when clean. When it got dirty, maybe 16-18 lbs.. But then I noticed shorter and shorter durations between cleanings, until it got to the point where the thing would only run for an hour or two after I hosed it down, before the pressure would shoot back up to around 20-22 lbs. At that rate there wasn't enough water pressure going back into the pool to run my little Polaris Turtle.
I did the filter test by running system with and without cartridge. Huge difference. 10-12 lbs. without, 20-22 lbs. with. Without the cartridge, my Turtle almost jumped out of the water. No clogs, pump ok, so it's my cartridge right? I was given a variety of solutions by different sources. Started with cartridge cleaner spray. Moved on to an overnight soaking in TSP solution. Also tried an overnight soak in garbage can with water and pool shock. All these solutions produced some lowering of pressure, but only temporarily. Within a day, right back to square one. Then I found out it was not good to hose cartridge with too much pressure. I had been using one of those little cone shaped nozzles on my hose that produce a hard stream. So I concluded I must have damaged the cartridge, so I bought another one.
Life was bliss...for a while. By the following summer I was back to square one again. The only difference being, I wasn't using the hard spray nozzle to clean with. I did buy one of those soft brush wands that attach to your hose and allow you to brush between pleats of cartridge. I bought this because I noticed it was quite slimy and slick way down between pleats, and just hitting it with a light to moderate hose spray was not getting that out. But alas, that too proved futile in the face of the powerful pressure demon. So I forked out another $150 for a new cartridge. That was in June of 2012. I've been pretty good until now. My pressure has been creeping back up the past few months, and is now back where it was with old cartridge. So I've got yet another one ordered.
I guess a few words about my chemistry are in order, as my original question pointed towards this as a possible culprit. First off I haven't used anything in my pool in a couple of years besides Chlorine tablets, shock, and pH increaser. I've taken my water and had it tested, and was told my pH was on the low side. I've always struggled to keep it even as high as 6.8, and at times I've let it go even lower. I just found out that makes for terribly acidic water and could do damage to the system. So in the past couple of days I've added lots of increaser and raised the level to about 7.6. However, I think the damage is done. After hosing cartridge, pressure is back up to 22 lbs. within an hour or so. I don't know if my chronically low pH levels could be the culprit here?
Any help would be greatly appreciated. Thanks for staying with my book so far. I'll end it here. Thanks for your time.
Sincerely,
Jeff
PS. I guess I should mention...now that I have my pH up where it should be my total Alk. is off the charts. But maybe that's a topic for another discussion. I love my pool, I love my pool, I love my pool
