AG, 22k gal.
Just bought Doheny's 24" filter and have a Waterway PD140 coming.
Just a simple single line from skimmer and one return. No chlorine feeders, heaters nor any water features.
Looking to hard plumb with 2" PVC. Cureenr setup (pic) is 1.5hp cartridge filter with crappy ball valves. Obviously all those and the flexible hose will go.
The question I have is should I even bother with valves?
If I need to isolate the system, I use the rubber stoppers.
The only valve I can think would be useful would be between skimmer and pump to easily clean out pump basket. But the filter itself has a "closed" on the multiport, so that's basically a ball valve.
Looking at Kaplan 2" valve. They're $40/ea so wanting to make sure I'll actually need 2?
