Fiberglass pool build in Ohio
Awilli8203
Active member
Sep 7, 2012
44
Pittsburgh
I have used my auto cover as a winter cover in pittsburgh for 6 years and just replaced the material. It does fine with the weight of the snow. One thing to wacth out for is that when you leave the pump on the cover over the winter to pump out water which you should do, sometimes as the snow melts the pump will run but the pump hose is frozen solid so no water comes outwhich can burn out your pump. A sparehose kept inside will help to fixthis
bmoreswim
Platinum Supporter
6,444
Central MD
So as a comparison, our autocover has seen 5 seasons of use which is probably covered a total of 3+ months out of 7 our pool is open. Based on the very good condition of the fabric, I wouldn’t be surprised to get 10 years out of it.
bobbyseal
Active member
Jun 21, 2017
39
Columbus, OH
We got the forms installed and the area back filled.
Easytouch and screen logic are working. I did plug the ethernet cable from my screenlogic straight into my network switch and it is working just fine.
The pool builder is going to get his electrical inspection on Monday and then has concrete being delivered Tuesday. It's really starting to look like a pool!
Pool handrail is all bonded and ready to be installed once concrete has been poured.
Autocover is ready to be installed!
bmoreswim
Platinum Supporter
6,444
Central MD
Looks great! Well done brushed concrete is under-rated. I presume they'll be back to cut some expansion joints?
bobbyseal
Active member
Jun 21, 2017
39
Columbus, OH
Yeah,
He'll be cutting the expansion joints once it sets up. There are a couple spots where he wasn't as pleased with the finish of the concrete, but it looks fine by me. I like the broom finish. Deck chairs don't wobble like they would on stamped concrete. He'll be getting the concrete poured for the pavilion in the next few days.
BMK
445
SW PA
FWIW, I too use my autocover as the winter cover. I do lay a leaf net* over the cover until all the leaves come down, then remove the net (usually early Dec.). After that I pretty much forget about it except for the occasional frozen pump hose as has been previously mentioned. Cover fabric lasted 8 years. Would have replaced it this year but we are building a new pool in it's place.
* leaf net tip...never buy a pool leaf net from a pool supply house. Get a pond leaf net from any landscape supply or big box chain. Exact same thing at much lower cost. At least that has been my experience.
bobbyseal
Active member
Jun 21, 2017
39
Columbus, OH
Some more work got done. Expansion joints were cut into the concrete. Work is underway for the pavilion base. Sonotubes have been placed for the posts. Inspection should happen on Monday. He'll probably pour Tuesday or Wednesday next week.
In the picture above, the area between the form and the pool equipment pad will have a vinyl privacy fence. The rest of the pool will be fenced with aluminum pool fence. The conduit just behind the form contains Cat6 wire and speaker wire. I should have some solid 5 GHz wifi out there and a Sonos Connect amp inside the house will power some outdoor speakers. Hoping for an early spring!
bobbyseal
Active member
Jun 21, 2017
39
Columbus, OH
Thanks Maddie,
We are really happy how it is turning out. Tomorrow, they are going to install the autocover and probably do the winter shut down. It'll be nice to turn the pump off and save some money on electricity! I need to figure out some program settings on the pump for next season to provide enough chlorine from the SWG, but not constantly waste electricity running the pump if it's not necessary.
Otherwise today was a good day. I'd say the pool builder "made the grade!";) It's nice to have the big mound gone from our backyard!
YippeeSkippy
14,592
Evans, Georgia
Oh yeahhhhh... I hear ya about the mounds of dirt. The mud was tracked everywhere....ugh! We had to wipe the dog's paws off each time she came back inside.
Maddie :flower:
jimmythegreek
In The Industry
Aug 10, 2017
2,828
Morris Cnty NJ
Looks great u guys did a nice job w the layouts. Nice property too u have the room for it all and then some.....btw my pool is 13k gallons and I have a 40k SWG lol
bobbyseal
Active member
Jun 21, 2017
39
Columbus, OH
Yeah,
I forget how it worked out. I think I asked him to buy a larger cell, but he had already gone and got the smaller one because it worked “fine in the last pool he built.” Our pool builder was just starting out. Took a bit of a risk. Price was right. I’m pleased with how it turned out in the end. But I think our PB learned a lot....
Anyway, once this one dies out, I’ll just get a larger one the next time around.
