Moved from HERE.
I have experience with this issue as I found my 2 year old pool had faded and was not as glossy below the water line last spring and I thought this could be the reason. I was following the TFP pool water chem stats and I will admit not that well during winter of 2018. I had left my SWG on as a source of chlorine and there were days that it was running 24/7 with the pump due to freezing temps and although I put it at 5-10% production I was not checking the chlorine nor PH throughout this 1-2 month period and assumed that I could get it all in order upon warmer weather. Having had my pool for over a year and really just concerned with PH, to the 7.0-8.0 and chlorine level high enough with CYA I always tended to the higher side of chlorine, shooting for 5 .0 but ending up closer to 6-7. My calcium and TA were in range during the season with TFP standards. Upon this fading I went into full research mode. I did not trust the manufacturer because of others' experience on here and my pool installer said he had not seen the situation. I believed him and still do because he had proven to be a man of great integrity throughout our install and always followed up with issues. He sent his tech who has maintained all types of pools for 25 years out immediately. She gave me the manufacturer recommended balance numbers with CH 350-400, TA 80-120 and said she had never had the issue with clients she had trained for these numbers. She said she never got above 5.0 on CL. There had also been issues with over doses of chems in our pool early on due to miscalculations of water so I have no 100% reason. I just know that when I started noticing issues my numbers were Cl 6.5, PH 8.2, TA 60 and CH 157, CYA 70. Other than adjusting the ph, TA to compensate and possible CH a little, those numbers would have been pretty typical for my pool. When I went to the pool store in distress they said get TA up and no worries with CH because = fiberglass pool and wouldn't even sell my calcium without a water sample when I told them I wanted to get it up to 350-400 based on manufacturer's recommendation! Last time I went there but I digress.
I called the resource I used to decide on a fiberglass pool, former rep for my manufacturer but no financial interest in my situation and he has since gone on to manufacture his own brand of fb pool. He is also on a board of fb pool manufacturers associations. He stated that if my numbers were that during the winter with the ph as high as that and possibly higher with the SWG on constantly the pool could fade in a matter of a couple of weeks and that that high CL over a few months with other chems in balance could fade the pool. It was his opinion over 5.0 CL on a regular basis based on experience, but his FB manufacturers would say 3.0. He first recommended getting CH manufacturers guidelines because the calcium acts a buffer as well as alkalinity I also saw on here that helped one person's situation so I did that. In the process of research I even called a scale expert in Australia to see if I could get a test from him to see if it was scale. While he could not ship products, I talked with him at length. He stated in Australia, almost 80% of pools are fb and have SWG. He said my normal CH level would be unheard of there where they are closer to 1.0-2.0 and we agreed his area is very similar to my TX climate. When I explained the CYA chlorine situation and how it would be impossible for those levels with 70-80 CYA, he said most people there do not use CYA BECAUSE SWG are constantly adding CL and very small amounts kill pathogens quickly with no CYA. He advised to the let the CYA burn off and have no more that 3.0 of free CH in the pool at any time, shooting for 2.0. It was within the TFP guidelines for CYA of 30 so I decided to try and just let my CYA go down and adjust target CL levels with normal drains with rain and slight reduction of water when I needed to add anyway. This was in May 2019 and while I do test my pool every day, very rarely did I have to adjust any chemicals frequently other than PH and once every couple of weeks for TA to be 80-90, keeping FC levels to 1.5-3.0 and CC never above .5. I never had to shock the pool, and it stayed just a clear as ever, although with the higher CH it does not have the very light soft feel. This is a small issue compared to damaging the gel coat further. Since then the fading has not gotten worse and the glossy feel got better so I am assuming there was some scale or the calcium helped seal the finish. I had the water recycled at the beginning of the season this year, leaving almost 0 CYA and have noticed great volatility in chlorine numbers , but never to the point of having CC go beyond .5 or algae problems. For this reason I did add CYA to 20 just to help with balancing after recycle. That might be the level that works with keeping the FC level down , agrees with TFP chlorine levels and for now, I don't see a downside except the difficult test in my opinion.
I am still in experiment mode but so far, so good and both very experienced consultants attest that with these numbers my pool coating will look the same 10-20 years from now and incur no further damage. It is my belief that the prevalence of CYA use is for people to be able to have a pool maintenance contractor check levels once per week and shock the pool if needed frequently. I would never be comfortable with that and it appears that it is not conducive to the FB SWG combination at all. In the end, the FB manufacturers recommended chem levels seem to be more important in a FB pool as it is a lot easier to correct plaster finish that FB.
I realize there will be people whom will disagree and I readily admit this is experimental but having combed this forum for 3 years, I am seeing time and time again fading and chalking issues with new FG pools and I am looking for actual success stories with the longevity of FB pool finishes and the few people I have consulted have these successes on a REGULAR basis. They have no financial interest to tell me otherwise and I am choosing to trust them. I still value very much the information here and appreciate this site for giving me information in order to take my pool care into my own hands. I value others' input whether they disagree or not and whether they have had issues or their pools look the same as 10 years ago. We are all doing the best we can to preserve our investment and leisure. Thanks for listening.
