Hi all
I have a Taylor K2006 test kit which gives me readings of around 4ppm FC (which line sup with what I’m expecting after adding chlorine etc…)
However, out of curiosity does anyone have any explanation as to why other DPD 1 tablet based tests (both rapid colour chamber comparison and photometer based tests) would only ever give readings of less than 1ppm using the same sample?
I’m fairly certain I’m using all test kits correctly so just curious what might cause both DPD 1 tests to be similar to each other whilst both being so vastly different to the k2006 results?
FYI, the test kits I’m comparing are
Taylor K2006
Water ID Pool Lab 2.0 (Water Tester 2.0 in the US) (Photometer)
Water ID Pool tester (rapid)
Taylor K2006
