Newbie here I have an 8000 gallon liner pool. We just refilled it because I wasn’t able to get any kind of chlorine reading even after dumping 5 lb of shock in at the time. CYA was at 130. I’m in Houston.
So I bought the test kit. Made the switch to liquid chlorine. Clean pool with fresh water. Adjusted pH. Added some CYA. Last night my FC was at 0 (24 hrs after refill with tap water which initially had some chlorine in it). So I added 1 gallon of liquid chlorine from Leslie’s (10-12.5% concentration). According to pool maths, it should have gotten me up to an FC of 12. I added the chlorine after sunset.
This morning right at sunrise I got those numbers:
Ph-7.5
TA- 80
CYA- maybe right at 30 or a little less
FC- 5
CC-0.5
Question: how come FC didn’t get all the way to 12 with a whole gallon of liquid chlorine? Is this normal? I can’t afford to add an entire bottle every day. So if the sun wasn’t out, and it’s brand new water that shouldn’t be contaminated, where did the chlorine go?
Ph-7.5
TA- 80
FC- 5
CC-0.5
