This may be a remedial question but this is my first FC pool. Old pool was SWG and I didn’t maintain myself.
If you look at my testing logs here: PoolMath Logs
it feels like I’m adding an excessive amount of chlorine to the pool every other day. Usually anywhere between 32-64 oz. even then, when I test the following day, or miss a day, it drops from 5/6 to 0. Should I be concerned?Do I not have the fc high enough?
im in Austin TX and then UV is starting to get pretty high during the day. Does the FC loss occur in higher temps or higher UV?
thanks
thanks
