When slamming (which I've had to do twice this season - once to open, and once just this week when CC went > 1PPM), I use LOTS of R-0871, since at [e.g.] 25PPM FC, I need 50 drops of R-0871, potentially 3 or 4 times per day (morning test, 2 tests thru the day, and 1 evening test for my OCLT). This is at 0.5PPM/drop based on a 10ml sample. Is is reasonable to go with a 5 ml sample to yield a 1PPM/drop to reduce the amount of R-0871 I use? I would only use this during the day as the morning and evening OCLT samples need to be very accurate.
