May 2025 Update: (Failed with first 60 days) First look at Pentair's new IntelliChlor Plus30
The unit has failed with a control board sensor error. It lasted less than 2 months.
So after having some issues with Pentair and my old SWG unit I was given the opportunity to give the new Pentair PLUS SWG platform a shot and ended up with an IC30+, which is part of their new model line of salt water generators.
I'm not cool enough to do an unboxing video so instead here is a picture of the box telling you what's inside.
Check out that new acid washing kit. Pretty fancy.
I was told this is a drop in replacement for their current line of SGWs and I would be able to take the old one out and put the new one in. I'm coming off an IC30 so moving to an IC30+ was marketed as being easy to do if you already have the plumbing. The box also comes with adapters if you have their other sized units.
Turns out they were right. It's the same size as what I had and installation consisted of unscrewing the unions, taking the old one out, putting the new one in, and screwing on the unions. I don't have much more to say about the install other than that because that's all that it took. I did give the o-rings a coating of lube since I was in there and might as well since it was exposed. I have a Power Center and this one plugged right in, same size 4 pin connection on the end of the cord so nothing much to say there either. Overall the install was as promised, a direct drop in.
I don't have a before picture so lets just pretend I posted that, instead here is a side by side after.
A couple more action shots from the side
Powering on the unit it now shows a boot up reading sequence.
To access the buttons there is now a slide down cover instead of a pop up lid
The unit now will also tell you the current reading on the salt levels, which apparently my pool could use another bag, and if you scroll through the info also can get an easy reading on temperatures, run time, voltages, other warning states, model, and software versions. I think the old one did this as well but I never pushed whatever buttons were required to do so. Now there is a big INFO button right there so you can't not just go push it and see what happens.
It's only been a half hour since I got it set up so these are just initial impressions. Tomorrow will be the first full day run so I'll be going out there to see how it's working. Ran it tonight for a little while, made sure there were no obvious leaks, set it the chlorination up, watched it blink a few times, and set it back to my daily schedule. I do not have any automation but I do have a Pentair pump hooked into the Power Center with it's communication wire so the two units talk to each other enough that the SWG only runs when the pump is running.
Hopefully this first look is interesting to folks as I am not sure who has these style units yet.
