Expensive Closing
PoolGate
9,986
Damascus, MD
Jandy Aquapure 1400
Every year my pool closing company increases their prices. I think I will do it myself this year. My only real concern is the main drain. Can anyone point me to a good video of the main drain?
They also insist on a firm date for closing. I explained to them that I close based on water temp but they don't care. If I miss my date they go forward like another month.
Also as far as blowing water out of the heater, is it just, "blowing water out of the heater"?
I know where all of the equipment drains are located so I am not anticipating any issues.
I do not have a "cyclone" blower but may pick one up. I am not sure my shop vacuum can provide enough air. I have an air compressor but that only provides like 5 SCFM of air.
Blowout Underground Lines Only
PLAN C: Blowout Underground Lines Only
------- $379
o Lower water level as needed
o Remove water from underground pipes and add antifreeze as needed
o Backwash filter and/or hose off elements
o Winterize filtration equipment
o Install customer’s freeze plugs
o Provide a pool evaluation and Winter Warranty
o Work performed by our Certified service technician
The cyclone is well worth it. I couldn’t blow out very much with my shop vac or air compressor.
PG,
I was thinking about closing my pool this year, but digging it up and moving it to MD, just seemed like a little too much effort to me... :mrgreen:
Wish I could help, but know zip about pool closings..
Definitely invest in a cyclone, or a very good shop vac with blower side, if you want to do it. An air compressor is inadequate. You need HIGH flow and LOW pressure to blow out lines … compressors are the exact opposite of that.
