We are expecting to get several inches of rain from hurricane Sally starting tomorrow. Should I drain some water from my above ground pool or just let it run over?
If water can spill over without getting trapped between the liner and wall in your set-up, you could probably go either way. If your CYA and/or CH are high, lowering before the rain hits would be the best way to lower them. Good luck!Should I drain some water from my above ground pool or just let it run over?
what does 21" do to your pool? Completely overflowing?we hit 21" worth and finally it quit raining. the wind was wild and it looked like a wave pool for the past two days.
glad it's over .... finally.
I am draining some of mine out now, it's about a 1/2" from over flowing
