Error Code on Heater / how to resolve
JamesW
21,547
Note, I can still use the heater via my remote or control panel, it's just that the keypad is non-functional, correct? Thanks again, tstex
The heater should still work with the keypad disconnected, but you won't be able to change the set temperature or change modes.
tstex
1,869
Houston, TX
Guys
i had the circuit breaker turned off to the heater and when i went to the e/pad to clean pump basket, i decided to turn on the breaker. When i did, i heard 2-3 soft clicking sounds while standing at heater. the keypad is still unplugged and i got the same error as when plugged. See pic i just took...does this mean it’s the c-board that’s bad now? Is there something else i can do to test?
tstex
1,869
Houston, TX
No, the keybad has not been replaced.
I unplugged the keypad wire harness from the circuit board, reassembled and when I turned it back on, the display went back to the normal "bo" when the VSP was on low speed, which the bo reading is a normal display. Since the keypad is unplugged, I just turned off the circuit breaker. As noted above, when I flipped on the circuit breaker, the error code is now the same as when the keypad was plugged in...currently, the keypad is unplugged.
markayash
2,697
Atlanta Ga
I replaced that whole assembly on mine, it had the Sb light also. It's been a while but seems like the first time I bought a keypad separate and had issues.
tstex
1,869
Houston, TX
Most likely, it's a bad display board.
I had already ordered the keypad assembly which will arrive tomorrow, thursday...if I install and all works, then I'm good to go. If new one does not, then I'll order the c-board and try the original keyboard assembly. If old one works, I'll send back the new keyboard assembly. IF old one does not and the new one does, then I'll keep both the new parts installed. Sound correct? Thoughts...
thank you
Reactions: markayash
JamesW
21,547
Note that there is a display board and an Integrated Control Board.
They are both circuit boards.
I suspect that the display board is probably bad.
tstex
1,869
Houston, TX
Well, part came early and i installed the keypad assembly and it immediately went to “bo” upon turning the pump on so i thought i was home free. Then it turned back to the error code in about 5-10 secs.. So i guess I’m ordering the display board.
I’ll try display board w old keypad assembly first. If it wks, I’ll send back the keypad / if no and it takes both parts, then that’s that. Here’s the pics / thank you
tstex
1,869
Houston, TX
Just received the display board but wanted to run this by the electronic folks to see if there’s an issue.
The side of the board w the components seems to have a raised “bubble-like” area where the plastic “shrink-wrap” did not adhere down to the green surface of the board. Is this going to be an issue if it later breaks or opens and allows the soldered areas to oxidize? It seems like everything in the center below the actual display icon has the raised/sticky area. The top half of the board is fine. It’s an actual Hayward OEM Product.
Thank you and pls advise, Tstex
tstex
1,869
Houston, TX
The one that's in the heater now is not like this...I am going to send it back and make note that before the replacement is sent, that it needs to better checked...I have seen many printer circuit boards and have never seen this...
JamesW
21,547
Can't tell if it's going to be a problem or not.
You have to decide if it's worth the risk or send it back for a replacement.
