Erosion Around Pump
aarogb
23
Sanford, NC
Hi all,
I am first year pool owner and I have gotten my pool in good working order, but there is another issue that I have noticed that I am trying to take care of. We are starting to have pretty bad erosion around our pool pump and filter base. See attached images.
I was curious if anyone else has had this issue? If so, what has worked to combat it? I have started building a retaining wall around it, and I got about halfway done and I started to wonder if it would really work... (Probably should have asked this question before I started!). Just curious if a retaining wall is the right choice or is there something else I am missing?
Thanks
Aaron
kimkats
48,355
Tallahassee, FL
I would think hard about removing everything from that plastic pad and pouring a proper cement pad before thing go south with the pipes from that pad giving way from the erosion under it. If you do a cement pad you can dig down and make it nice and thick and put up a small lip to keep the rain from washing under it as it comes off the pool deck.
